Welcome to the National Soft Wash Alliance, America's Number One Free Networking and Training Forum. Join Today
Post Info TOPIC: Down Stream Injectors - Ten Things You Might Not Know
  1. Too much hose can cause downstrem injectors to stop working.
The more pressure hose the more resistance there is to push the water through the hose. This creates back pressure and reduces the velocity of the fluid through the constricted area in the downstream injector. So typically downstream injectors will work up to about one hundred and fifty feet of pressure hose before they stop drawing chemical.
  1. Gravity can cause downstream injectors to stop working.
As the low pressure nozzle gets higher than the down stream injector the back pressure increases until it reaches the point that it will no longer draw chemical. This usually begins to happen at distances of ten feet and higher, and can be less based on the length of pressure hose.
  1. Downstream injectors are designed to work in one direction.
All downstream injectors have an arrow on the body to indicate the direction of flow. If you put it on backwards, you will still be able to get flow, but you will not be able to draw soap.
  1. Downstream Injectors are designed for a specific flow range.
Downstream injectors work by restricting flow and creating a vacuum. This is known as the venturi effect. An orifice that is too large will not restrict the flow enough to create a vacuum. An orifice that is too small will create too much vacuum and also create back pressure which is bad for your pump. The standard ratings are 2-3, 3-5 & 5-8 gpm. They assume that the operator is using about 100 feet of pressure hose.
  1. A fixed injector will draw soap at a fixed rate.
A higher gpm pressure washer will have a higher dilution ratio.
You can control the ratio by mixing stronger or weaker mixes.
An adjustable injector will allow you to adjust the rate of draw and change the dilution rate on the fly. More control over the soap usage means more control over costs.
  1. All downstream injectors will dilute your mixture.
Pay attention to soap concentrations when you buy chemical. In order to use a downstream injector, the end solution of the chemical being applied must be effective at dilution rates of 8-1 and higher.
  1. Downstream injectors last a lot longer if you rinse them out after every job.
Caustics and acids left in your injector, line, gun, and wand can cause them to wear our quickly. Before you put your equipment away for the day, it is best to place your chemical line in a bucket of clean water and flush out the line. Then make sure the external surfaces are clean.
  1. They can be placed at the beginning or the end of your hose.
You could use a roll over nozzle holder to switch between high and low pressure if you prefer to use your chemical injector at the beginning of your hose. This way you can change pressure and leave the injector in the line. No need to return to the machine to turn off the soap. But, what if you need more than 100 feet of hose? No problem, just move the injector down the line. It can even go on the end of your wand just before your nozzle.
  1. A soap line strainer is a must have item.
Debris can cause abrasion in your lines and even get stuck causing restrictions. This causes your equipment to wear faster. Clogged nozzles and guns can also require you to stop a job for a field repair. Time is money.
  1. You can use an upstream injector and a downstream injector at the same time.
Let's say that you want to clean concrete with Clearly Clean X-Treme, and you also want to add Blue Boost. You could use an upstream injector for your Blue Boost to meter into your flow before the pump. Then you could introduce the caustic Clearly Clean x-Treme with a downstream injector.
Posted in Spray Tips by Clyde Hemminger
I have never used a soap line strainer and no problems so far.
http://elephantroofcleaning.com/
Benson, NC.
David Hoover
919-207-0666
This needs to be a sticky for the new guys.
Also, might I also add:
Always have 2-3 spares for every machine at all times! They last anywhere from a day to a year. Also a pro-tip. If the injector stops pulling, remove the injector hose and poke inside of the barb.
Pressure Washing Fairfax VA
Trey Winslow Patriot Pro Clean Inc
Pressure Washing and Soft Wash Roof Cleaning
PatriotProclean.com
 Thanks Trey!
Good stuff guys ,this helps answer lot of issues I had last year. Thanks
Saccarappa Exterior Cleaning
Tayib Helms
Westbrook, Maine 04092
30265258_1965603620420762_26798680328676
207-206-5613
Lol yeah i wished i had this printed out for guys to remember...
The arrow points in the direction the water flows.
Not "I'm stuck with dis guy"
Great post Brett. I learned a few new things
Do you any of you use an x jet?
