Some people have A/C stains on their asphalt shingles, it usually is becuase the drainage tube runs out onto the shingles leaving a White gooy look. I have had some success with toilet bowl cleaner....has anyone had any luck with another product?
Oct 31, 2013
F9 for sure.
does it clean up quickly? Do I rinse it with a hose afterwards? Thanks Zach.
Nov 1, 2013
I usually pre wet, Treat at 50-50 and then rinse very well. Maybe I've been lucky but I've had success every time I've used it.
Yes. F9. And yes rinse well so it doesn't leave a residue.
Thank You Gentlemen!
OMG make sure you dont let F9 dry on the shingle. Use very weak solutions to start. Rinse it while its wet. I learned this lesson in the most painful way possible.
It'll reduce your yearly gross by $3k.
Ed...thats going backwards!!!!! REVERSE...all engines REVERSE!!!!!
