The NorthStar® NSQ Series™ 12V On-Demand Diaphragm Pump is a premium-quality on-demand diaphragm pump that upgrades your sprayer with innovative components and engineering for superior spot or broadcast spraying performance. 100% continuous duty rating with no cool down period required.
What's Included
(1) Diaphragm pump
Best-in-Class, Industrial-Grade Pump
No Cool Downs Required
Finally, a sprayer pump built to work as hard as you do without losing its cool. The industrial-grade NSQ Series on-demand pump is an engineering marvel, boasting an impressive 100% duty cycle. That means while the competition is waiting for their overworked, under designed sprayer to cool down, the NSQ Series pump isn't even working up a sweat.
Lasts 5 Times Longer
Building the best sprayer starts with using the best pump. With patent-pending DXS-3™ valves featuring chemical-resistant Viton, exclusive NSQ Series pumps provide faster priming, better performance and best of all, last up to 5 times longer than other brands.
Packed with Features
This NorthStar NSQ Sprayer Pump is packed with components that are designed to reduce wear and keep working, like a Honeywell MICRO SWITCH™, a Santoprene™ diaphragm and a chemical-resistant fiberglass-reinforced polypropylene pump manifold. The innovative smooth valve design provides faster primes. It also has our unique pressure switch, designed to slowly cycle the pump to reduce switch and motor wear. To conserve battery power, we gave it an automatic power switch that turns off when no flow is needed. When other pumps are in for repairs, the NSQ series is still on the job.
The NorthStar Advantage
Industry-Leading Warranty
NorthStar sprayer pumps are built to last. But to give you extra peace of mind, we stand behind our product with an industry-leading 2-year limited warranty.
Guaranteed Satisfaction
Shop in complete confidence, knowing Northern Tool + Equipment protects your investment and is ready to provide you with the assistance and helpful resources you need.
Superior Service and Support
Should you ever need service or support, help is a phone call or e-mail away. NorthStar's field-trained technical staff is ready to help. For convenience, our professional in-store service department performs all repairs on site. Replacement parts are stocked at our Northern Tool + Equipment warehouse and ready to ship the same day your order is received.
ive heard some guys getting 2 years out of these pumps! no a bad find
Industry-Leading Warranty NorthStar sprayer pumps are built to last. But to give you extra peace of mind, we stand behind our product with an industry-leading 2-year limited warranty.
How can you go wrong.
Feb 28, 2014
Looks good
The delvan 5800 is 130 without shipping this one is 164 with one yr guarantee and shipping if pressure wash store going to be in Jersey I'd grab the 5800
Product Summary
What's Included
(1) Diaphragm pump
Building the best sprayer starts with using the best pump. With patent-pending DXS-3™ valves featuring chemical-resistant Viton®, exclusive NSQ Series pumps provide faster priming, better performance and best of all, last up to 5 times longer than other brands.
This NorthStar NSQ Sprayer Pump is packed with components that are designed to reduce wear and keep working, like a Honeywell MICRO SWITCH™, a Santoprene® diaphragm and a chemical-resistant, fiberglass-reinforced polypropylene pump manifold. The innovative smooth valve design provides faster primes. It also has our unique pressure switch, designed to slowly cycle the pump to reduce switch and motor wear. To conserve battery power, we gave it an automatic power switch that turns off when no flow is needed. When other pumps are in for repairs, the NSQ series is still on the job.
NorthStar NSQ Series 12V On-Demand Diaphragm Pump — 5.5 GPM @ 60 PSI
Manufacturer's Warranty: 24 months consumer / 90 day commercial
Have A Question About This Product?
Shop NorthStar
Product Summary
What's Included
Features + Benefits
Top of pageKey Specs
Top of pageCustomer Reviews
Product Summary
What's Included
Features + Benefits
Top of pageExtended Warranty
