The FallTech Contractor Universal Harness is an easy to don, adjustable harness with features you wouldn't expect on a budget harness, including lanyard keepers.
*Size
Choose an Option...S/LX-Large2X-Large +$5.00
* Required Fields
Regular Price:$49.95
Special Price:$34.97
Qty:ADD TO CART
Availability: Usually Ships in 1-2 Days Need It Faster? Give us a call 1-888-412-7289
What next? The red mouth ball with the head strap? You guys up north are starting to scare me and need some warmer weather SOOOOON!!!!!!!!
Ray its good to always carry a Roof Harness in your truck and to make sure you train your guys on how to use it. You can't make them put it on when your not on the job. But if its in the truck and they fall without it being on. It may cover your azz with OSHA.
From the Osha Site
Roofing
Low-slope Roofs
Each employee engaged in roofing activities on low-slope roofs with unprotected sides and edges 6 feet (1.8 meters) or more above lower levels shall be protected from falling by guardrail systems, safety net systems, personal fall arrest systems or a combination of a warning line system and guardrail system, warning line system and safety net system, warning line system and personal fall arrest system, or warning line system and safety monitoring system. On roofs 50 feet (15.24 meters) or less in width, the use of a safety monitoring system without a warning line system is permitted.
Steep Roofs
Each employee on a steep roof with unprotected sides and edges 6 feet (1.8 meters) or more above lower levels shall be protected by guardrail systems with toeboards, safety net systems, or personal fall arrest systems.
TRAINING
Employers must provide a training program that teaches employees who might be exposed to fall hazards how to recognize such hazards and how to minimize them. Employees must be trained in the following areas: (a) the nature of fall hazards in the work area; (b) the correct procedures for erecting, maintaining, disassembling,
and inspecting fall protection systems; (c) the use and operation of controlled access zones and guardrail, personal fall arrest, safety net, warning line, and safety monitoring systems; (d) the role of each employee in the safety monitoring system when the system is in use; (e) the limitations on the use of mechanical equipment during the performance of roofing work on low-sloped roofs; (f) the correct procedures for equipment and materials handling and storage and the erection of overhead protection; and, (g) employees' role in fall protection plans.
Employers must prepare a written certification that identifies the employee trained and the date of the training. The employer or trainer must sign the certification record. Retraining also must be provided when necessary.
GLOSSARY
Anchorage-A secure point of attachment for lifelines, lanyards or deceleration devices.
Body belt-A strap with means both for securing it about the waist and for attaching it to a lanyard, lifeline, or deceleration device.
Body harness -Straps that may be secured about the person in a manner that distributes the fall-arrest forces over at least the thighs, pelvis, waist, chest, and shoulders with a means for attaching the harness to other components of a personal fall arrest system.
Connector-A device that is used to couple (connect) parts of a personal fall arrest system or positioning device system together.
Controlled access zone-A work area designated and clearly marked in which certain types of work (such as overhand bricklaying) may take place without the use of conventional fall protection systems—guardrail, personal arrest or safety net—to protect the employees working in the zone.
Deceleration device-Any mechanism-such as rope, grab, ripstitch lanyard, specially-woven lanyard, tearing or deforming lanyards, automatic self-retracting lifelines/lanyards-which serves to dissipate a substantial amount of energy during a fall arrest, or otherwise limits the energy imposed on an employee during fall arrest.
Deceleration distance-The additional vertical distance a falling person travels, excluding lifeline elongation and free fall distance, before stopping, from the point at which a deceleration device begins to operate.
Guardrail system-A barrier erected to prevent employees from falling to lower levels.
Hole-A void or gap 2 inches (5.1 centimeters) or more in the least dimension in a floor, roof, or other walking/working surface.
Lanyard-A flexible line of rope, wire rope, or strap that generally has a connector at each end for connecting the body belt or body harness to a deceleration device, lifeline, or anchorage.
Leading edge-The edge of a floor, roof, or formwork for a floor or other walking/working surface (such as the deck) which changes location as additional floor, roof, decking, or formwork sections are placed, formed or constructed.
Lifeline-A component consisting of a flexible line for connection to an anchorage at one end to hang vertically (vertical lifeline), or for connection to anchorages at both ends to stretch horizontally (horizontal lifeline) and that serves as a means for connecting other components of a personal fall arrest system to the anchorage.
Low-slope roof-A roof having a slope less than or equal to 4 in 12 (vertical to horizontal).
Opening-A gap or void 30 inches (76 centimeters) or more high and 18 inches (46 centimeters) or more wide, in a wall or partition, through which employees can fall to a lower level.
Personal fall arrest system-A system including but not limited to an anchorage, connectors, and a body belt or body harness used to arrest an employee in a fall from a working level. As of January 1, 1998, the use of a body belt for fall arrest is prohibited.
Positioning device system-A body belt or body harness system rigged to allow an employee to be supported on an elevated vertical surface, such as a wall, and work with both hands free while leaning backwards.
Rope grab-A deceleration device that travels on a lifeline and automatically, by friction, engages the lifeline and locks to arrest a fall.
Safety-monitoring system-A safety system in which a competent person is responsible for recognizing and warning employees of fall hazards.
Self-retracting lifeline/lanyard-A deceleration device containing a drum-wound line which can be slowly extracted from, or retracted onto, the drum under minimal tension during normal employee movement and which, after onset of a fall, automatically locks the drum and arrests the fall.
Snaphook-A connector consisting of a hook-shaped member with a normally closed keeper, or similar arrangement, which may be opened to permit the hook to receive an object and, when released automatically closes to retain the object.
Steep roof-A roof having a slope greater than 4 in 12 (vertical to horizontal).
Toeboard-A low protective barrier that prevents material and equipment from falling to lower levels and which protects personnel from falling.
Unprotected sides and edges-Any side or edge (except at entrances to points of access) of a walking/working surface (e.g. floor, roof, ramp, or runway) where there is no wall or guardrail system at least 39 inches (1 meter) high.
Walking/working surface-Any surface, whether horizontal or vertical, on which an employee walks or works, including but not limited to floors, roofs, ramps, bridges, runways, formwork, and concrete reinforcing steel. Does not include ladders, vehicles, or trailers on which employees must be located to perform their work duties.
Warning line system-A barrier erected on a roof to warn employees that they are approaching an unprotected roof side or edge and which designates an area in which roofing work may take place without the use of guardrail, body belt, or safety net systems to protect employees in the area.
Capital Roof Wash said
Mar 13, 2014
My bad Art. Not a joking matter. Great info on the subject BTW.
Now how am I going to choose?
Call them and ask for the best starter harness. Its just going to sit in the truck so I wouldn't go crazy buying the best.
-- Edited by Art O on Thursday 13th of March 2014 01:03:09 PM
Mar 13, 2014
home depot sell the harness in a 5 gallon bucket in the roofing section.. Has the harness, hand brake, 50' life line and roof anchor.. I think it was just over 100$.. we have 2 in the truck just because
Jeff said
Mar 13, 2014
Yep, same here. Bought my kit a Lowe's for about 100 and keep on the truck for when and if I need it. Have not had to use it thought, so far so good with the ladder and gutter line. I have read you have to watch the line for wear as the roof solutions will eat at it. Maybe get a bleach resistant line.
I bought a 32 foot expandable pole and the nozzle spray kit from SWS Both for the roof spry and a DI filter. All ordered at the Orlando event.
V/r Jeff
Sounds good Jeff
PRISTINE ROOF CLEANING said
Mar 19, 2014
Nice vid!!!! did not look like you need it on that roof.... I like your knot "taunt line hitch" Its what we use for repeliing out of trees.
Wow!
Good old thread, Bumping it up as a reminder to be SAFE for the start of the season
-- Edited by Art O on Wednesday 12th of March 2014 09:54:00 AM
Hey I might like to get one too! We had a guy fall off a roof last year, but he had his harness on. I wasnt there so I dont know the details.
0
0/0.0
Home > Safety Products > Fall Protection > Miller® Harnesses
Miller® Harnesses
NO.
CART
Be the first to review this product
Regular Price: $49.95
Special Price: $34.97
* Required Fields
Miller TechLine 60 ft. Horizontal Lifeline Kit for Residential Construction - 2 Workers
Regular Price: $1,499.95
Special Price: $1,299.97
ADD TO CART
Super Anchor Max Fall Protection Kit
1 Review(s) | Add Your Review
Regular Price: $159.95
Special Price: $129.97
ADD TO CART
DBI-SALA Compliance in a Can
Regular Price: $164.95
Special Price: $149.97
ADD TO CART
French Creek RKB Roofer's Kit
Regular Price: $165.95
Special Price: $134.97
As low as: $124.97ADD TO CART
FallTech Contractor Roofer's Kit - 50 ft.
Regular Price: $179.95
As low as: $129.97ADD TO CART
Miller Ready Roofer Kit
Regular Price: $219.95
Special Price: $184.97
As low as: $179.97ADD TO CART
DBI-SALA Compliance in a Can Light
Regular Price: $99.95
Special Price: $74.97
ADD TO CART
FallTech Fall Protection Starter Kit
Regular Price: $84.95
Special Price: $64.97
ADD TO CART
Guardian Bucket of Safety Roofer's Kit
Special Price: $169.97
ADD TO CART
Guardian Sack of Safety Roofing Kit
Regular Price: $249.95
Special Price: $224.97
ADD TO CART
Guardian Li'l Bucket of Safety Kit
Special Price: $84.97
ADD TO CART
Guardian Aerial Lift Kit
Regular Price: $89.95
Special Price: $79.97
ADD TO CART
French Creek Deluxe Roofer's Kit
Regular Price: $180.95
Special Price: $155.97
ADD TO CART
DBI-SALA Roof Anchor Fall Protection Kit
Regular Price: $599.95
Special Price: $569.97
ADD TO CART
From the Osha Site
Roofing
Low-slope Roofs
Steep Roofs
TRAINING
GLOSSARY
V/r Jeff
Roof Soft Washing on youtube
