| NEVER |
52.9% | |
| STANDARD PROCEDURE |
17.6% | |
| REALTORS / PM'S ONLY |
11.8% | |
| WE SPRAY MULTIPLE APPLICATIONS - NO NEED TO RINSE |
17.6% |
This is a poll to gauge the number of contractors who rinse or do not rinse after Soft Washing.
If we are working for a realtor and the roof is gray, has very bad staining and they need it COMPLETED by the weekend,..then we rinse,..doesn't happen that often.
If we are cleaning any gray shingle roof with really bad staining,..we will spray multiple light applications to kill the mold,..sometimes though on gray there will still be a brown haze on the spots that were really bad. No shame in that,..after all we just killed something so there's bound to be a brown patch of dead stuff left behind. Many times the flow of the product will pull most of it off, which is why I don't like a soapy mix..but really bad spots can leave a patch of brown no matter what.. Then we will rinse the heavy spots and blend it with the rest so be residual o there aren't eye catching patches of brown haze.
If the customer is a really hot chic and I'm trying to be on the job longer than need be. Plus I'll do her concrete at no charge.
And finally, if I feel like it,..and that's not very often neither.
We only rinse cedar, slate, and if the roof has no gutters. Or if they are putting it in the market for sale in the immediate future
Honestly it's the one area of this business I just don't get. I have watched others (via video and in person) spray a roof and their mix drips off the roof without a care........when the're done they go into the rinse the plants and grass mode and no worries. If I allow any mix at all to drip off, without my ground guy spraying it, I end up with burned grass and plants.
I thought my mix was too strong so I toned it done. Sprayed.......waited.......waited....waited (I'm not patient at all) and the streaks remained. I then sprayed 3, 4 and five coats to get the desired results.
Now I spray a light coat at the edges and go heavier elsewhere and I rinse. I rinse because stuff dies if I don't.......maybe it's just the humidity here???? but if I do not rinse......gutters or not......stuff dies.
If they have rain gutters I am sure to end up with dead grass at the downspouts if I don't do two things.
#1. I bag the gutters.
#2. I rinse at least the first 5 feet.
I do think the heat has been my biggest problem this year. The mix is insta heated to 170000000 degrees when it hits the roof so any roll off is an insta kill on anything it hits.
I rinse.
Doug,
try pre wetting the roof a little when it is really hot. Seems to help a little
We always do multiple light quotes but that doesn't equate to not needing to rinse. The brown haze of the dead bacteria is always there to some degree unless we rinse. Another reason we will decide to rinse is that in the summers we commonly go moths without rain. I don't like the idea of leaving it looking like that considering what I charge.
I only rinse roofs that have no gutters or areas of no gutters which is far and few between. I do go back to rinse Lichen after two months for a fee. I don't like it because there still can be granule loss during rinsing. I may have a secret in another week that def. helps reducing granule loss when rinsing two months down the line....if it works it was discovered on accident. { have to go back for a 2 month rinse }
-- Edited by Patrick G on Saturday 6th of September 2014 12:22:58 AM
A have just left a bit to the rain also .on my last job CBA standing on the opposite ridge on a friday night ..
but will have to rinse as a compete with peoples ideas of pressure washing a roof clean for peanuts over here .
HO .are getting wiser slowly .about pressure washing a roof .The damage and mess they cause is helping my buisness .pick up
We rinse cedar, slate and metal. We do not rinse asphalt unless there are no gutters and around here 95% of the homes have gutters.
You need to vote before you can see them and you need to be a member to vote
Who?
Good to know Google likes us!
Hot Topic on FB
