I have been washing my Whites with Clorox 2. https://www.clorox.com/products/clorox-2-stain-remover-and-color-booster-liquid and it seems to clean them better. They say to brush it on the stain to make it work better. I'm wondering if this stuff would work with cleaning canvas awnings. It has a color brighter in it. I think this stuff may work good.
Hey Art, I may be mistaken,..but I think Clorox 2 and any other color safe bleach uses Hydrogen Peroxide (Liquid) or Sodium Percarbonate (Powder),.. as it's active ingredient. Both are essentially the same thing.
If an awning is very moldy I can't imagine this stuff working as well as Sodium Hypochlorite and soap.
It would be ok as a maintenance cleaning detergent,..as Sodium Hypochlorite will damage fabrics over extended use.
-- Edited by Jeff Wible on Wednesday 24th of September 2014 01:29:53 PM
Hydrogen Peroxide and fabric brighter according to the labile. There's nothing there that says don't add bleach.They say to brush it into the fabric for better cleaning. Like I said it cleans my whites and I think it may work on awnings to get them cleaner. I'm going to have to wait until next Spring to try it. Unless one of the Florida guys gives it a try!
Not sure about Hydrogen Peroxide liquid,..but Sodium Percarbonate powder mixed with bleach will make a volcano of soap bubbles.
Works fine in my washing machine. Needs some testing on awnings. But I think it will work good if you can use less S/H
I use the same ratio as I do with my house wash and get fantastic results. I wet down the awnings first then apply. Let it dwell for about 10 minutes and rinse. Then rinse again. (rinse until you do not see bubbles from surfactant/soap)
Ray one of the reasons I'm looking into this stuff is the color brightner in it. It should help.
I Product: CLOROX 2® STAIN FIGHTER & COLOR BOOSTER - ORIGINAL (LIQUID)
Description: TRANSLUCENT, BLUE, VISCOUS LIQUID WITH A FRUITY, FLORAL ODOR
Other Designations Distributor Emergency Telephone Nos.
Clorox Sales Company
1221 Broadway
Oakland, CA 94612
For Medical Emergencies, call 1-800-446-1014.
For Transportation Emergencies, call
1-800-424-9300 (Chemtrec).
II Health Hazard Data III Hazardous Ingredients
Eye irritant. This product contains hydrogen peroxide, which may cause
temporary skin irritation or skin whitening after prolonged contact with the
concentrated product.
No medical conditions are known to be aggravated by exposure to this
product.
FIRST AID:
EYE CONTACT: Flush with water for 15 minutes. If irritation persists, call a
doctor.
SKIN CONTACT: Rinse with plenty of water. If irritation persists, call a
doctor.
INGESTION: Drink a glassful of water. Call a doctor or poison control
center.
INHALATION: Remove to fresh air. If breathing problems develop, call a
doctor.
Ingredient Concentration Worker Exposure Limit
Hydrogen peroxide 3 - 7% 1 ppm - TLV-TWAa
CAS # 7722-84-1 1 ppm - PELb
secret pixels 1 - 5% Not established.
CAS # 3332-27-2
aTLV-TWA = ACGIH Threshold Limit Value - Time Weighted Average.
bPEL = OSHA Permissible Exposure Limit - Time Weighted Average.
None of the materials in this product are on the IARC, OSHA, or NTP
carcinogen lists.
IV Special Protection and Precautions V Transportation and Regulatory Data
Hygienic Practices: Wash hands after direct contact.
Engineering Controls: Use general ventilation to minimize exposure to
product mist.
Personal Protective Equipment: Wear safety glasses. Wear rubber or
neoprene gloves for sensitive skin or if there is the potential for prolonged
skin contact.
DOT/IATA/IMDG: Not restricted.
EPA - SARA Title III/CERCLA: This product is regulated under Sections
311/312. This product contains no chemicals that are regulated under
Section 313 and contains sodium dodecylbenzenesulfonate
(CAS #25155-30-0, <0.1%), which is regulated under Section 304/CERCLA.
VI Spill Procedures/Waste Disposal VII Reactivity Data
Spill Procedures: Absorb and containerize. Wash residual down to sanitary
sewer. Contact the sanitary treatment facility in advance to assure ability to
process washed-down material.
Waste Disposal: Dispose of in accordance with all applicable federal, state,
and local regulations.
Stable under normal use and storage conditions.
VIII Fire and Explosion Data IX Physical Data
Not flammable or explosive. pH............................................................................................................. 9 - 10
Specific gravity ............................................................................................~1.0
Viscosity (cP) ...........................................................................................~1200
Solubility in water ...................................................................................Soluble
©1963, 1991 THE CLOROX COMPANY
DATA SUPPLIED IS FOR USE ONLY IN CONNECTION WITH OCCUPATIONAL SAFETY AND HEALTH DATE PREPARED 4/2008
