I installed a filter in my system earlier this year. Then recently I noticed the pressure of the Devalan FB was lower than normal. I inspected the filter to see if it was clogged. You can say it was more than clogged. Referring to the photo the SH severely deteriorated it impeding flow. When I got the filter I knew better that it must be stainless steel but was not thinking. Right now I'm just running without a filter. Lesson learned...
Hank, the end line strainer looks like the one I originally had that was included in the system I purchased from Pressure Tek. It was stainless steel and held up well. But I no longer use a drop tube.
Dave,
The 8" strainer is the one I'm referring to. It had a 80 mesh plastic screen. I'm on a slate roof cleaning job and I don't have the catalog in front of me. I use the one from Bob's kit.
Back home now so I added the info in photos.
-- Edited by waxman18324 on Tuesday 28th of October 2014 08:46:26 PM
-- Edited by waxman18324 on Tuesday 28th of October 2014 08:48:06 PM
Same here...where do you get yours Eric???
www.dultmeier.com/products/0.2623.2631/2458
Dave,
All of my tank pick up tubes have 1/8" holes drilled in them. The pump has a SS wire filter with a site glass.
