What size ladders to most of you carry? When I was estimating roofing jobs, I carried a heavy duty 28' and a lightweight 20' that was easy to pull off the truck. What sizes are common for roof cleaning? Will be cleaning a lot of 2500-3000 sq ft. two story homes.
Bryan, From smallest to largest...
This three sectional is a life saver for porch roofs and to get to the roof above the porch.
20', 28' & 36' We have some tall homes here and have never needed a 40 (than God!)
I have two of these since we seldom have more than two ladders in use. Since they came as a three part set I got the base units only for the other ladders. The levelers aren't cheap but in all my years I find them to be the most stable and solid construction.
Brett
went through this last year i carry a 24' and a 32' both fiberglass with standoffs. might add a small 12' or 16' this year for small homes. havent cleaned a roof yet that the 32' didnt reach
We carry a 32' with stabilizer and have a 40' at the shop. We also carry an 8' A frame and have a 12' at the shop.
What is the A frame used for mostly? Hadn't thought about needing one of those.
I carry a 16 and 32.
20' and a 24 but sometimes a 32' then there's the 36'
Bryan
Tripod A-frames are excellent for outdoor use esp needing to go over bushes. Standard 4 legged A frames are not good on uneven terrain or having to go into the bush.
Some homes have so much landscaping that you can't get an extension close enough.
HTH
My trucks have a 32' and a 10' step ladder. That's it. We have never needEd more. Most of the time we never even break out the 32', because we use the step ladder.
Over the years I've accumulated (buy, trade, gifts and found) many ladders including 40'. My residential truck carries 16, 24 and a 32. The last ladder I bought for $100 was a 40'. Now I have two. We use the 40's about 20 times a year. All ladder sizes have their own ladder standoffs/stabilizers, which we paint safety yellow.
One other thing about ladders. Never get rid of them if they are damaged. If you're manufacturing something for your truck they come in handy. They are great for holding 5 gallon carboys in place or making platforms.
Feb 28, 2016
16' & 28
Andy Hinson wrote:
16' & 28
Sounds like I'm on the right track. I loved the 28 when I was roofing. It was tall enough to get most anywhere, but more manageable than a 32 for one person.
Honestly it depends on the size or type of the majority of homes you work on. By that I mean if a majority of homes are ranches you don't need much more than a 16,24 etc. Some towns near me are 90% colonial or Tudor style so would need a 32, others all ranches 16, etc. Figure out your market needs but it's always good to have a wide array available even if it's knowing a buddy that has that 40 you can borrow for that once a year.
16,24 are my most used and kept on truck most of the time. have 3 of each then of oddities like 20,28,32,40 that are 1 each at shop for when needed. But my Tripods are the most useful. If a house has a lot of landscaping in front that makes getting an extension up, an 8ft trip allows me to get up high to shoot from gutter line
Agree the 28 is a good comprise
-- Edited by Maverick Contracting on Sunday 28th of February 2016 07:52:15 PM
Maverick Contracting wrote:
...But my Tripods are the most useful. If a house has a lot of landscaping in front that makes getting an extension up, an 8ft trip allows me to get up high to shoot from gutter line
I'll check out the tripods. I've never used one but it sound like a good idea.
Don't get a "landscapers" tripod,although you can I prefer fiberglass types
-- Edited by Maverick Contracting on Sunday 28th of February 2016 07:56:01 PM
So true Hank. If we have a damaged section I keep the good one and strip off all the parts. I carry two lengths of different sizes for the occasional roof we need to get to. There are only used with the roof hook.
Brett,
I've only used those once and shortly thereafter I was looking for someone to do my laundry.
Broken ladders can usually be used as chicken ladders as even if railings are damaged most of the weight is on the roof so they are still safe in roof walking application
Just a quick reminder....If you have any broken or damaged ladders in your shop, they must be locked and chained up. If OSHA just decides to pop in, you could get a fine. They do not want an employee to grab one of the decommissioned ones by mistake. I know a roofer that was fine $4500.00 per broken ladder. He had five of them stacked up.
Thanks John.
We carry two extension ladders - 12' for single story and 28'. On occasion, we will rent a 32' or 40'. Also we occasionally carry a chicken ladder with ladder hooks when cleaning cedar roofs.
Mar 1, 2016
I carry a 16' 24' and 32'. Have a 40 that i have only used 3 times in the last 5 years.
Jeff Thompson said
Mar 2, 2016
Funny. I'm going to sell my 32' today. Bought it when I started and probably only had to use it 5 times. Just lays around. Figured if I only need the 32' for not even 1% of my jobs I can let those go by. Getting to old to lug that thing around, knees getting to old to climb the thing also. I can always rent one if I want the job bad enough.
I carry 16' and a 24'. Gets me through 99% of the jobs that come my way.
Step ladders---4' and 8'
Extensions----16' 20' and 28'
I decided to start with a 16' Type II (225 lb), and a 28' Type I (250 lb). Gonna look into those tripod step ladders too. That seems like a great idea.
Michael Wedge said
Apr 19, 2016
We use the 28' from lowes with the built in leg extensions on both sides And the 22' multi adjustable A frame or extension ladder. I think in the last 3 years I may have broke out the 32' 5 times. I just realized they have a 26' multi-position on line. Might grab one of those turns into a 13' A frame
Werner 28-ft Aluminum 225-lb Type II Extension Ladder
Werner 22-ft Aluminum 300-lb Telescoping Type IA Multi-Position Ladder
Werner 26-ft Aluminum 300-lb Telescoping Type IA Multi-Position Ladder
Brett
HTH
http://m.homedepot.com/p/Werner-12-ft-Fiberglass-Tripod-Step-Ladder-with-300-lb-Load-Capacity-Type-IA-Duty-Rating-FTP6212/203134298
