Pressure washing/Roof cleaning trailer: with proportioner
Josh Brown said
Nov 28, 2016
This trailer is completely plumbed, anchored and ready. It's a total pressure washing and roof cleaning business, all it's missing is you. I'm buying a new rig and I'm selling this one. Includes:
- 5.5 gpm, 3500psi hot water pressure washer. Vanguard motor, general pump. Set up for Down streaming. Bypasses to water tank - 4 gpm 4000psi cold water pressure washer. Honda motor, general pump. Set up for down streaming. By passes to water tank - 4 summit hose reels: 2 for garden hose, 2 for PW hose - 200' of PW hose on two of the reels, 400' total - 250' of garden hose - roof cleaning system with titan hose reels, battery, 12v pump, kuri tech hose, gun, nozzles etc - 2 PW wands, down streaming soft wash nozzles - 2 verticals 50g tanks: 1 for down streaming house wash, 1 for roof cleaning - 1 pro-portioner - mixes water, chemical and soap in the line for desired ratios. No mix tank required, pro-portioner does mixing for you. - 325g water tank - Hudson float valve - Generated - booster pump for rinsing roofs and bushes when roof cleaning - 19 in surface cleaner: whisper classic - tool box - new ladder rack - 4 new tires - trailer new, double axle with breaks - 6x14
for photos click here: http://raleigh.craigslist.org/for/5886107171.html
- 325g water tank
- Generated
- tool box
- new ladder rack
- 4 new tires
252.314.8284
wjbrown1986@gmail.com
Yes sir it is 252.314.8284
