Hey Art,..I've seen both good and "bad" reviews on it. The "bad" meaning,.it works,..but not any better than the General Hi-Draws. So,.the bad is the price tag for no more than a Hi-Draw will get you.
*Gotta watch these high advertised draw rates,..they can be rated using a 2 GPM machine with 25' of hose,.and that would bring the draw rate up considerably compared to an 8-10 GPM machine. So yes,.the claim may be accurate,..but it's the "UP TO" phrase that gets people on items like this. People usually read into something as pertaining to their own setup,...
My opinion,.they are too much money to even try out. Now,..if they made it so the ball doesn't stick,.that would make it worth it,Ha,Ha.
I'm thinking about getting an X jet to keep on the truck for bad area's when needed. No a big deal to use when needed.
I am working on the 12V chemical injection to have plumbed into my DS injector,..and use when needed. I am gonna have it tied into the soap injector and have it wired to my remote,..so when the solenoid is open the pump will turn on and the pump will turn off when the solenoid is closed.
Either gonna use 3 way valve or use the two port soap injector,.and use one port for the regular DS'ing,..and have the 12V into the other port,.and use it when needed. I'll have the 12V on a switch so it's not turning on by remote when it's not being used.
The only thing about the remote valves is they don't hold up to the S/H. I would be better if you could find a inline valve that worked off a small motor. That could turn the valve off and on.
I get a month out of my remote valves Art,..at $12.00 each it's a non issue. Even at $60-$70 it's a non issue,..the value of a remote controlled DS unit is priceless.
The valves are Poly with a EPDM seal. Works very well for me.
Jeff have you looked into a car fuel pump yet?
On;y when I need one for my truck or van,Ha,Ha,..
Jan 14, 2017
Jeff any chance of a video of your setup?
I don't even own anything to take a video.
Jan 14, 2017
Not even a smart phone?
No,..I use old flip phones. I don't like smart phones,..I love the technology and I'd be messing with it all the time. I prefer the old style flip phones,..talk and text.
Any of you guy ever use the SSS Super Sud Sucker from Enviro Spec. Says 33/50% draw. They seem to be on the expensive side.
http://envirospec.com/chemical-injectors/
