I think Russ could answer your question but I also think the best thing is to have the injector for the gpm.
Yes its a regular injector but it has an adjuster to throttle back.
I just looked at these closer and the gpm's. Do you think these would work well for us? Some times you need more and others less. What do you think Mike?
Thinking the same thing.
They might be useful say when your doing a house that is stucco up front and vinyl siding on the three sides. Other than that i dont really see a purpose.
If this is the same injector its not going to work for us
Chemical Kit, High Pressure ST-64 Up Stream Injector
Apply soap at high presssure. Restricts waterflow to create suction.
I was searching Goulds Boosters and found this. Is this a regular D/S injector? There's more there with different GPM
https://www.kleen-ritecorp.com/p-3960-38-adjustable-siphon-injector-flow-15-gpm.aspx
