Not sure what you're looking for but it says "air operated".....just wanted to be sure you knew.
Aug 24, 2017
I run them on one of my systems. Work great. They are air operated. I run them anywhere from 100 psi down to 20psi if I am spraying small areas of deck or concrete. I run roof chems and oxalic thru them and not a problem. I have two of them set up so if I need to spray a little further, I run both at the same time.
Steve Sabella said
Sep 17, 2017
I have 2, a viton for roof mix and a kalrez for acids.
Quite happy with them, switched from a12v system and glad I did
Upward Prowash said
Dec 13, 2017
I replaced my 12v pump with this model. It works great and can be run at any PSI up to 100. I run mine with a small electric compressor on board. I added a 2000w power inverter to the battery bank to run it.
Has ran twice as long already than the 12v pump.
Anyone have any thoughts on or experience with this pump?
FloJet G57
