Water dragon 8 gallon pressure washer getting ready for 2018 season. We run a K7 unloader with a unloader block. This pressure washer has a y strainer on inlet supply line. Its has a Udor pump at 8 gallon and is 3500 PSI. Honda motor is a GX690 with all the drain tubes for easy oil changes.
What this price tag and if you can let me know how much shipping is to Honolulu, Hawaii 96813
I will shoot you over a estimate today.
Erik
You should do a video or some kind of comparison between the 5.5 gallon and the 8.0 gallon. I have the 5.5 and I'm super happy with the performance but I heard a few guys in Tampa say there is not a ton of noticable difference. also how hard is it to change my machine to and 8 gallon.. can I just change the pump and is it just a unbolt the 5.5 and bolt on the 8.0
I will have to do that. 8 gl is run off a GX 690 and 5 gl is run off a GX 630.
There is a HUGE difference in a 5 to a 8. I will never run a 5 for residential cleaning always a 8.
The 5.5 was recommended to me when I had the skid built. I know your doing a comparison of a 3/4 booster vs 1hp booster. You should also do a comparison of a 5.5 vs 8.0 gal
Thanks Erik
That's Eric with a c.
