I tried the Agent Clean bleach enhacer this week. It definitely works and I'm considering using it for the rest of the spring and maybe the summer.
Apr 6, 2018
Devils advocate but did you test it against the same cleaning without it?
I wonder if its an Oxidizer like Fresh and Clear
You talking about AgentGreen? I really think the roofs clean better with it.
Do they clean better or Faster? Big Difference in both.
I just notice that I less often have to hit roofs with a third application when using either SWS Green Wash or Agent Green (the two products seem about the same to me. I've used both).
Jim Prom said
Apr 6, 2018
I use SWS greenwash as well, it is good stuff.
It really is. I use several SWS products. Agent Green is very similar to Greenwash. Probably by design.
Apr 7, 2018
Greenwash is honestly my favorite surfactant for roof or house washing. I never did any split test so there is nothing to substantiate. But man oh man does it smell good!
http://www.softwashsystems.com/greenwash/
https://www.softwashsystems.com/terrawash/
HHandywork said
Apr 7, 2018
I was curious about this product Agent Green, nice to hear you guys like this one. Noted on the other products mentioned that I will need to try SWS Greenwash. I pickup some Roof snot to start this year with. There is a lot of other products with the Agent Clean lineup arsenal. I wonder if you could add Secret Agent which is a foaming agent that prevent runoff to the Agent Green bleach enhancer product, which this is probably a question for Ray?
Mike
It definitely works faster in the cold weather and I used alot less SH. I'm going to mix Agent Clean ( Surfactant & Enhancer). It was time for me to try something new and I like it so far.
Jacob Hittler said
Apr 8, 2018
Pure Gold here gents. I went with the SWS Green Wash too because of the 6x strength for shipping costs. But am eager to try the Agent Shield lineup after seeing some of it in action and talking with others at the PWS PA event.
-- Edited by Jacob Hittler on Sunday 8th of April 2018 03:26:00 PM
Interesting! 6x strength? I'm trying to figure which way to go with this. Sorry but I have problem with one of the suppliers so I'll see where this post goes.
Jim Prom said
Apr 8, 2018
and they have been selling the scent in green wash for a year or so, try so rain fresh in your soap tank!
Ok im following. Being winter is staying untill June im.gonna habe to start cold weather cleaning and need a boost for the mix
Well we worked yesterday and the roof mis worked awesome. Was 34° out yesterday morning. In all my years of roof Cleaning I've never tried to clean when it is this cold.
Fresh and Clear from leslie's pool supply
Art
I actually have a bucket of the fresh n clear and I never used it. I'm thinking about adding it to my soap tank and see if it works like the agent green. Just not sure about playing chemistry
Art I actually have a bucket of the fresh n clear and I never used it. I'm thinking about adding it to my soap tank and see if it works like the agent green. Just not sure about playing chemistry
Add it to your water tank, not soap.
Mario said
Apr 10, 2018
I clean roofs when it's just above freezing. Just use a hotter mix.
Same hear Mario. Looks like we in the 80's by Saturday. Then we be back to 50's by Monday. Luv'in It.
Mario said
Apr 10, 2018
Go git em
Art
It would be better to add it to my Soap tanks. I water the bushes through my water tank.
Using the bleach enhacer I'm not using alot of sh
Zach does greenwash kill the smell of bleach?
Western Mass Prowash said
Apr 12, 2018
With Brian's recommendation, I just order some agent green from Lisa to help in these crazy temps.
HHandywork said
Apr 13, 2018
Likewise I need to get this as well
I just ordered my Agent Green. We'll give it a try!
We started last year using a combination of Agent Blue and Agent Green We use very little of the products thru the proportioner and we do use less SH so we like the results. I just put a little of the Green in with the Blue and throw the draw tube in the container and go to work.
Agent Green definitely helps when your Spring Temperatures are a bit colder than usual. Whatever usual mean anymore in Western PA!
Mike
