I am sure one of my trucks has an injector issue so I started searching since a complete injector replacement could be around 2K. I found this from Sea Foam and thought I would share it in case others could use this approach.
Brett,
Have you used this on your Landa unit?
Hsnk
waxman18324 wrote:
Brett,
Hsnk
I am going to see what it will do to the burner. I have a new nozzle so I'm not concerned about any damage. I plan to replace it but I want to see what will happen. I will also see what this does to the sluggish take off with one of the trucks. It idles a bit rough and slow take off from start but does fine once it gets going.
Hsnk
