I'm about curious what product you like to use when you come across soot from furnace or propane vents that are venting out the side of a structure. I've run into this a few times with some house cleanings on vinyl siding. House mix cleans it up a little but not completely. I have F9 and one restore on the truck. I wondering if you guys use any other products that work good with this situation or recommend anything else because I'm concerned after cleaning it with the chem I got, that it will stick out just as much as the soot.
Mario said
Jun 12, 2018
You need a good degreaser.
EBC
What both Mario and Hank said. Just left them know that the area will have a bit of a sheen since you will also be removing the oxidation.
HHandywork said
Jun 13, 2018
Thanks Mario,Hank and Brett for the advice. I do have EBC on hand ,that I will use for the first time and be sure let the customer know about sheen look after.
