Trying to get a small softwash system put together. Looking to do it DIY style. Can anyone lend some insight.
Not looking at going large scale until I figure out if people will go for it.
Needed to know
Basic equipment
Chemicals/mix ratios
And the process.
Thank y
ou
drew0379 wrote:
Trying to get a small softwash system put together. Looking to do it DIY style. Can anyone lend some insight. Not looking at going large scale until I figure out if people will go for it. Needed to know Basic equipment Chemicals/mix ratios And the process. Thank y ou
There is a lot of information here, use the search bar where you can find more than enough information on building everything from small 12v systems, down streaming and booster pump set ups. Also check out Safety and Information. Once you start researching and come up with some kind of plan there are many who will help with fine tuning.
Please got to New Member Introductions and start a new thread. Fill out your signature.
