When was the last time you looked at your roof? What does it look like?
Is there a lot of debris caught in valley's and other places?
Is it difficult to tell what color it's supposed to be?
Is there green stuff growing on it?
Do you have big trees towering over the house?
If you answered yes to any of these questions chances are you need a soft wash roof cleaning. Soft washing is a cleaning technique that uses detergents chemicals and soaps to breakdown and loosen the dirt and grime so they can be gently rinsed away. Contrary to power washing on long island which uses pressure to force off the dirt, softwashing uses no pressure.
You never want to let someone pressure wash your roof. We want to clean the roof to prevent any damage and premature wear. Using a pressure washer to do so is counter productive and will cause damage to the roof surface.
Roof cleaning typically takes a few hours and you get immediate results. Once a roof is cleaned it should stay clean for quite a few years. The less trees near the property usually the longer you can go between cleanings.
Keeping your roof cleaned and functioning properly will help prevent premature replacement. All you have to do is reach out by phone or website and we can schedule your cleaning quickly. Www.slateroofcleaning.com631-433-2703
-- Edited by DirtyRoofcom on Tuesday 17th of January 2023 10:17:44 AM
Keeping your roof cleaned and functioning properly will help prevent premature replacement. All you have to do is reach out by phone or website and we can schedule your cleaning quickly. Www.slateroofcleaning.com 631-433-2703
