A Soft Wash Skid is a self-contained unit specifically designed for the "soft washing" technique, which is a low-pressure cleaning method used on delicate surfaces like roofs, siding, and windows.
Here's a breakdown of its key components and functions:
Components:
Skid: A sturdy, typically aluminum frame that serves as the base for mounting all other components. This frame ensures stability and facilitates easy transport on trucks or trailers.
Water tank: Stores clean water for the soft washing process. Sizes can vary depending on the model and desired capacity.
Chemical tank: Holds the concentrated cleaning solution (usually sodium hypochlorite) used in soft washing. Smaller tanks are allocated for surfactants or other additives.
Pump: Delivers water and cleaning solution mix at low pressure, typically ranging from 50 to 200 PSI. This is significantly lower than traditional pressure washers, which can damage sensitive surfaces.
Hose reel: Holds a long, high-quality hose (often 100-200 feet) for reaching various cleaning areas. Some models might also include a spray gun and wand for precise application.
Valves and controls: Allow for regulating water flow, mixing ratios, and pressure settings, ensuring optimal cleaning results.
Benefits of using a Soft Wash Skid:
Gentle cleaning: Low pressure protects delicate surfaces from damage compared to traditional pressure washers.
Effective cleaning: Soft washing solutions effectively remove dirt, mold, mildew, and algae without damaging the surface.
Increased efficiency: Large water and chemical tanks minimize refill interruptions, allowing for continuous cleaning.
Portability: The skid-mounted design enables easy transport between job sites on trucks or trailers.
Organization: All components are neatly organized and readily accessible on the skid, improving workflow.
Who uses Soft Wash Skids?
Professional cleaning companies: Soft washing is a popular service offered by cleaning companies specializing in exterior cleaning.
Roof cleaning specialists: Many roof cleaning professionals rely on Soft Wash Skids for safe and effective roof cleaning.
Building maintenance teams: Larger facilities and property management companies sometimes utilize Soft Wash Skids for in-house cleaning needs.
Here are some additional resources you might find helpful:
Components:
