Post Info TOPIC: PW Oil
PW Oil
Can I use straight 30 weight oil in my PW pump or does it have to be Power Washer pump oil?
Hey Art, I've used 5w-30 automotive oil years ago with no issues. For the last few years I've used 5w-30 Mobil 1 synthetic,..probably doesn't make a difference,..but for just a few dollars more and a whole season of washing it's not much extra money. I usually change my oil every Spring and just keep an eye on it from there.
 That's what we use.
Are you talking about the oil in the "crank case"or seperate oil in the water pump? I don't know anything about it but I assume there is a seperate "water pump"
 Ya in my truck!
I thought a power washer has a seperate pump on it?
Art Mobil 1 for the motor, but I was told to use an oil geared for the pump.
I think I'm going to stick with the Cat oil from HD. It cost more but I trust it.
there are 2 types of oil with a detergent and oil with out detergent.
w/detergent is for engines
wo/ detergent is for pumps
 very good Mike
No,.any auto oil will work Art. Non detergent is irrelevant these days. But really,..it's all cost effective so do as you please.
-- Edited by Jeff Wible on Tuesday 18th of February 2014 04:47:04 AM
I like the Cat pump oil because its Blue. When its not blue anymore I change it. Its only a few bucks more.
Used the 30 weight oil. Went back to 4 cycle oil. Holds up better.
