TOPIC: SoftWashing and Pressure Washing in Central PA and Northern MD
Do you have ugly roof stains?
You are not alone.  These ugly roof stains have become an epidemic across the United States. Algae, mold, moss and lichen can be cleaned safely without the use of high pressure cleaning equipment.
Liberty SoftWash offers a safe and effective cleaning process called softwashing, which will completely sterilize your roof to eliminate the algae and mold growth without the use of a pressure washer or agitation by brush. Using a pressure washer or brush to clean a roof will remove the protective granules on your roof, shortening the life of your roof.  Additionally, pressure washing alone will not kill the algae at the root, which is needed to achieve a 99.99% kill ratio.  Since we are able to achieve such a high kill ratio, our cleanings will last 4-6 times longer than traditional cleaning methods.
This same softwash cleaning technique can be used on all of your home’s exterior surfaces such as vinyl siding, dryvit, stucco, and more.
We also offer pressure washing services for the concrete or asphalt at your commercial or residential property. Our pressure washing equipment utilizes both hot and cold water to achieve the best results possible in every situation.  From
Call Liberty SoftWash today for a free exterior cleaning estimate.  We service South Central Pennsylvania and Northern Maryland.
(717) 324-4208 Or visit our website at LibertySoftWash.com
Lisa Seitz
(717) 324-0392
Liberty Softwash
Roof Cleaning Pennsylvania
