Post Info TOPIC: SoftWash Roof and Exterior Cleaning Central Pennsylvania and Northern Maryland
 Liberty SoftWash offers professional roof and exterior cleaning in Central Pennsylvania and Northern Maryland. Liberty SoftWash specializes in a safe and effective soft wash cleaning technique that is ideal for cleaning all of your home's exterior surfaces.  Softwashing is a low pressure cleaning technique that will not only clean a surface but will also kill any algae or bacteria that may be growing. We have found that surfaces stay clean longer when cleaned using a soft wash method as opposed to traditional pressure washing with just water alone.
Our soft wash roof cleaning will return your home's roof to a like new condition by killing and eliminating the algae, lichen and moss that may be growing.  A dirty roof is not just an eyesore.  A roof with black streaks actually causes your attic space to heat or cool unevenly because of the hot spots caused by the algae growth on a roof.  Much like a dark shirt on a hot summer day, the black streaks collect more heat which also causes premature aging of shingles as well.
SoftWash roof cleaning is the only way a roof should be cleaned.  A professionally trained roof cleaning professional will only use pumps and other equipment that are designed to operate at low pressure and will never use a pressure washer to clean a roof.  A pressure washer, even at the lowest pressure setting runs at a pressure that will cause damage to a roof's surface.  You should never pressure wash your roof.  SoftWash cleaning is the only recommended technique to clean roofs.  All of the products used in our roof cleaning process are 100% biodegradable.
Give the professionals at Liberty SoftWash a call to discuss your exterior cleaning needs in Central Pennsylvania and Northern Maryland. (717) 578-5342
www.LibertySoftWash.com
Lisa Seitz
(717) 324-0392
Liberty Softwash
Roof Cleaning Pennsylvania
Nice Blog Lisa and Eric. Your Blog Posts are starting to show up real well on the internet
Thanks Art.
