Post Info TOPIC: Just made a starter softwash in a box
Aloha! Happy Turkey Day everyone! Just made a simple pump in box with 200ft 1/2 ag hose weather proof in off switch on the outside of the box. Any suggestions of what else I can do? It does not swen like it shoots 35 ft thought but today is really windy out here today. trades are like 15-20 mph
Sorry about the spelling 😀
Looks good Chris, drill some hole in the bottom in case water gets in there, maybe some vent holes too. I'm working on a build myself, It's going to be the Worlds lightest skid.
-- Edited by Art O on Thursday 27th of November 2014 06:59:52 PM
Will do thanks. My plans r to run a fan too.let me know when you make that system. I would be interested.
It's half way there, I'm waiting for the Fat boy to come from Bob at PT. It should be here tomorrow
Awesome ! Make sure you post pics. Hope not to much snow up there.;)
Chris,
If you can eliminate that elbow that would help with some distance and back pressure.
Sorry I did I was just doing a test run. I have 1 in hose going through the other side of my box to my tank. Thank you
Hank makes a good point. To expand on that build I would loop that exit hose with slack and clamp it to the side. If you accidentally pull to tight you can Crack the connection and cause SH to leak into the box and mix with the battery acid creating a very dangerous situation. (Acid +base=bad bad situ!) Also put that battery in a water proof box.
Also have that fan blowing in, not suckling out. Suckling out may pull corrosive fumes thru the motor corroding the fan and killing it.
Good luck!
-- Edited by Maverick Contracting on Friday 28th of November 2014 07:28:18 AM
Here's a pump I made about 3 years ago. I use it as a transfer pump and Back up. If you use Brass street elbows you will have less restriction then the PVC elbows.
http://nationalsoftwashalliance.activeboard.com/t55107703/side-winder-pump/
Maybe an ATV, GATOR with tank and pump mounted and just drive around those big properties? LOL
Thanks I will do that loop. Makes lots of scense😉
Sorry Art it won't let me view that link
 Not sure what's up with it, works for me, Search Side Winder pump on the forum.
Heres another build from last year or so. I washed many of roofs with this Rig
Art,
You're video is listed as "private".
waxman18324 wrote:
Art,
 OK should work now!
That's cool Art
