Post Info TOPIC: Hanny Hose Reel
Hanny Hose Reel
I'm thinking about buying this hose reel. Is it any good? It has a smaller foot print compaired to the 1/2". I'm hoping to get 250' of  1/2" hose on it.
Hannay Reels Series 1500 Live Hose Reel, 5/8" x 200' Hose Capacity, Max 3000 psi, Crank Rewind
Price:$310.28 + $18.95 shipping
Note: Not eligible for Amazon Prime.
In stock.
Usually ships within 2 to 3 days.
Ships from and sold by Rittenhouse.
  • Hose Capacity: 200' of 5/8" ID hose/cable
  • Compact reels designed for long lengths of hose in manual rewind
  • Direct crank rewind is permanently attached
  • Standard inlet: 90° ball bearing swivel joint, 1/2" female NPT threads
  • Standard outlet: 1/2" female NPT threads
  • Hannay Reels Series 1500 Live Hose Reel, 5/8" x 200' Hose Capacity, Max 3000 psi, Crank Rewind
Click to open expanded view
Art, I know nothing about that hose reel. I bought one of these four years ago and the only thing I have replaced is the manifold. It has held up well, the Liberty Co. is easy to order parts from and it holds 300' of 1/2 poly braided. I just ordered another for my garden hose and it's less expensive than what I paid in '10. They also have SS.
Liberty Hose Reel
Art,
With Delevan 12 volt pumps I would use a maximum of 200' of 1/2" hose, which should fit these reel with no problem.
I need a reel with a narrow foot print. I don't have a lot of room where I need to put it. The 5/8 reel is 4" narrower then the 1/2 reel.
Art, Hannay are probobly the best reels you can get. I have one that I purchased off an old ag sprayer system, it was used quite a bit and I have had it 3 years....sprayed nothing but bleach through it, rinsed everytime, and its still holding up. I have no idea how hold it is but I know its the original manifold and swivel. I may just buy a couple of those too.
The Liberty is the reel I used last year. I replaced the manifold with a stainless T before I 1st used it and I didnt have a problem with it at all, it worked well.IMG_20140513_195501_756.jpgIMG_20140513_195530_005.jpg
ReNew Roof and Exterior Cleaning
www.streakyroof.com
Gene Perkins
Charlestown NH
603-477-5562
