Post Info TOPIC: Grease Removal from a Restaurant roof
We were approached by a roofer to clean this TPO (membrane) roof at this local eatery. The hood cleaning company had obviously not been performing a proper and thorough cleaning for quite some time and the grease catch basin was not even attached to the fan system, allowing vented oils to spill on the roof. Leaks had formed inside, and the roofer was unable to even diagnose the issue unless the roof was either cleaned, or removed and replaced.
Very few parties involved in the process had hopes that a cleaning could provide the results that were needed, due to the advanced and extreme conditions. However, Spray Wash Exterior Cleaning was able to clean this mess and restore the roof to a condition where it could be inspected and repaired. Our Service basically kept this restaurant for having to replace their roof!
When you have grease issues, membrane roof problems or need a commercial cleaning, call Spray Wash. We can handle the most difficult tasks!
Great job Ray
That is nasty, Nice work Ray
Grease can be removed from a PVC or TPO membrane if the correct process is used. Spray-Wash of Tallahassee obviously has the right equipment and process to get your rubber membrane style flat or sloped roof cleaned correctly.
Wow, looks like a new roof! Great work!
 Professional Services To Irvine, Richmond, Berea, Winchester, Lancaster and Lexington, KY!
www.upwardprowash.com
upwardprowash@gmail.com
Call OR TEXT to 859-302-6380
