Post Info TOPIC: A few changes to the truck
A new remote for down streaming with a waterproof sealed remote switch and the 1/2" solenoid valves. I installed to the exterior for ease of maintenance of both the valve and switch. I didn't want a bigger box so this should work.
The booster got an isolator and a pressure switch. Due to the weather I am not able to test it yet.
More to come while I finish the 12V valve and switch for the buffer tank.
 Above my pay grade, I would like to swing by and check it out sometime.
The new float switch and 12V valve got to get a test yesterday and worked well. Now the tank gets about 6 - 8 inches more water.
 I think that is the same type of float switch I have in the tank now. In the previous tank I had a Hudson, very similar to what is in the toilet tank.
Brett, what does the isolator and pressure switch do for the booster?
info@AdvantageRoofCleaning.com
www.AdvantageRoofCleaning.com
Here is an earlier post. http://nationalsoftwashalliance.activeboard.com/t63143158/110-booster-pump/
 ah I see. Thanks Brett.
