For years contractors have been asking for more chemical induction performance. Most injectors will provide up to 10-12% through the injector. Super Suds Sucker injectors provide up to 3 times that much but quite often this is not enough to satisfy the needs of the contractor who is up against a real tough job. To answer this call we have re-valved and balanced a popular ShurFlo pump that will answer the call. When you install this 12-V pump between the Chemical Supply and Injector and your injector will draw as much as 3 times the normal performance rate.
Part # 1964 – Brass Injector
Each $89.97
Regular Price: $161.95
Part # 1964-SS – Stainless Injector
Each $119.97
Regular Price: $215.95
Part #: 5390CIS – Chemical Induction Pump
5.3 GPM @ 90 PSI with Viton Seals
Thanks Art,...The pricing is over the top for these items. Also,.they're missing a "VERY KEY" element to the DS injection system. What they are proposing is a rudimentary design, that will have numerous issues from the get go. Anyone who wants to do that for real needs to come here and do some searching for the proper way to set it up.
Correction: The prices may not be over the top for THESE items,..but a rudimentary setup like this can be done quite a bit cheaper and get the same performance.
-- Edited by Jeff Wible on Wednesday 1st of December 2021 06:24:41 AM
