Post Info TOPIC: How to Build a Pressue Washing, Soft Wash Rig
Building a pressure washing and soft washing skid can be a complex process, but with careful planning and attention to detail, it can be done effectively. A skid is a self-contained unit that can be mounted on a trailer or truck and used for pressure washing or soft washing tasks. This guide will provide you with a step-by-step process for building a pressure washing and soft washing skid.
Step 1: Choose the right pressure washer The first step in building a pressure washing and soft washing skid is to choose the right pressure washer. You need to consider the size of the pressure washer, its power, and the type of fuel it uses. A gas-powered pressure washer with at least 4000 PSI and 4 GPM is a good option for a skid. This will ensure that you have enough power to clean surfaces effectively.
Step 2: Choose the right soft washing equipment In addition to a pressure washer, you will also need to choose the right soft washing equipment. Soft washing involves using low-pressure water combined with specialized cleaning solutions to remove dirt, grime, and other contaminants from surfaces. You will need a dedicated soft washing pump, chemical injector, and specialized nozzles for this task.
Step 3: Choose the right tank Once you have selected the pressure washer and soft washing equipment, you need to choose the right tank. The tank should be large enough to hold enough water for your needs, and it should be made of durable materials that can withstand the pressure of the water. A 300-gallon water tank is a good choice for most pressure washing and soft washing skids.
Step 4: Mount the equipment on the skid Once you have gathered all the necessary equipment, it's time to mount it on the skid. The skid should be sturdy enough to support the weight of the equipment and the water tank. You will need to secure the pressure washer, soft washing pump, and water tank to the skid using bolts or other fasteners.
Step 5: Install hoses and fittings After mounting the equipment on the skid, you need to install the hoses and fittings. You will need high-pressure hoses for the pressure washer and low-pressure hoses for the soft washing pump. You also need to install quick-connect fittings for easy connection and disconnection of the hoses.
Step 6: Test the skid Once the hoses and fittings are installed, you need to test the skid to ensure that everything is working correctly. Turn on the pressure washer and soft washing pump and check the water flow and pressure. You should also check the chemical injector to ensure that it is working correctly.
Step 7: Add optional accessories Finally, you can add optional accessories to your pressure washing and soft washing skid. For example, you can add a hose reel to store your hoses and make it easier to move the skid around. You can also add a water heater to heat the water and make cleaning easier in cold weather.
In conclusion, building a pressure washing and soft washing skid requires careful planning and attention to detail. You need to choose the right equipment, mount it on a sturdy skid, install hoses and fittings, and test the skid to ensure that everything is working correctly. With the right tools and a little bit of know-how, you can build a high-quality pressure washing and soft washing skid that will meet all of your cleaning needs.
