Post Info TOPIC: Pro's and Cons to Paver Sealing
Paver sealing refers to the process of applying a protective coating over the surface of concrete pavers to prevent staining, fading, and other forms of damage. While paver sealing can offer several benefits, it also has some drawbacks. Here are some of the pros and cons of paver sealing:
Pros:
  1. Protection against damage: Paver sealing can help protect your pavers from damage caused by weather, UV rays, and foot traffic. This can extend the life of your pavers and keep them looking new for longer.
  2. Stain resistance: Sealed pavers are less susceptible to staining from oil, grease, and other substances. This can make them easier to clean and maintain over time.
  3. Enhance appearance: Paver sealing can enhance the color and texture of your pavers, making them look more vibrant and appealing.
  4. Prevents weed growth: A sealed surface prevents weeds from growing between the pavers, giving your outdoor space a cleaner look.
Cons:
  1. Cost: Paver sealing can be expensive, especially if you hire a professional to do it for you. The cost can depend on the size of the area to be sealed and the type of sealer used.
  2. Slippery surface: A sealed paver surface can become slippery when wet, especially if it's over-sealed or if a low-quality sealer is used.
  3. Limited durability: The effectiveness of the sealer can diminish over time due to wear and tear, and it will need to be reapplied every few years.
  4. Limited breathability: Sealing pavers can limit the breathability of the surface, which can cause moisture to get trapped underneath the surface and cause damage.
In summary, paver sealing has several benefits, including protection against damage, stain resistance, enhancing appearance, and preventing weed growth. However, it can be costly, make the surface slippery when wet, require reapplication over time, and limit the breathability of the surface.
Thanks Admin
