Post Info TOPIC: 5 GPM PW vs 8 GPM PW
Need to add a bigger PW to the van this winter and i have a few issues. Room for a Pw is not the problem as I'm removing my old PW. The problem I have is the size of my water tanks. I currently  have 2-35 gallon drums so approx 70 gallons total. I plan on taking one of the 35 gallon drums out and replacing it with a 55 gallon drum but that is all the room I have. even though the van is an extended verion van i have used every inch of it as i can . So here is my issue and some of you PW gurus may have a simple answer. I do very little housewashing so the way I do it now is I apply with my all-flo and I rinse with my Pw and the Pw is supplied by homeowners faucet. I was still planning on using homeowners water but using the 70 gallons as a buffer for the bigger machine. My plan is to pipe the tanks together and using hudson float valves on both tanks. But if my math is right i will have only so much on the trigger time before I run out of water. Here in Nh most of the wells put out 4-8 GPM, so if i use and average of 5gpm and i use a 8gpm PW my 70 gallon  tanks will give me approx 20 mins of trigger time. going to be calling Bob at PT today but I want to here it from you guys 1st. I also want the 8 gpm Pw not the 5GPM PW as I want to increase the speed of housewashing , because one of the reasons I dont push house washing is because Im to slow at it and there is a better ROI on roof cleaning. Im not Interested in a booster pump because I now only use fatboy as backup and I dont want any more electric pumps. Im an all-flow guy for life.
Brian I have an 8gpm for sale. I think you would need at least 100 gallon tank for either set up though. I use a 100 gallon tank on the 5gpm machine and a 250 on the 8 gpm machine.
We run 125 gl tank for our 8gl PW.
Mike why are you selling the 8gpm ? I can get to 90 gallons and that is it, so it sounds like I need to go with a 5 GPM and that is that. Mike how is your 5 GPM machine for downstreaming and house washing, either way a 5 GPM machine will be a ton faster than my old machine. And with any PW whether it is 5 or 8 GPM , is it really pulling 5-8 GPM . I would think that nozzle would slow down the gpm ?
Brian everyone knows that you are supposed to use a zero tip for every application.
 Dam, my high school education left me a little short in the brains dept.....as a matter of fact i never saw my diploma, they called my name and handed me it rolled up. I just asked my mother the other day if she still had it and if she ever opened it. All she recalls is that after i handed it to her and i went off to drink with my friends for the night. The paper maybe blank and the high school was just being polite buy calling my name.
-- Edited by Brian C Jackson on Tuesday 31st of December 2013 09:18:22 AM
I'd go with the 5gpm. Washing houses using well water, a small buffer and a 8gpm machine is no fun. You'll spend more time waiting on the water to fill back up than you will washing. With town or city water, you wouldn't have a problem. I see a lot of residential properties that have 1/2" cpvc or copper plumbing for outside spigots. This greatly reduces the flow of water and you will often only see 3.5-4.5 gpm flow with an 8gpm well pump. If you do go with an 8gpm machine, I'd recommend carrying an extra supply hose so you can connect to 2 water spigots when needed.
Maryland Roof Cleaning
Maryland Roof Cleaning    Delaware Roof Cleaning
Chesapeake wrote:
I'd go with the 5gpm. Washing houses using well water, a small buffer and a 8gpm machine is no fun. You'll spend more time waiting on the water to fill back up than you will washing. With town or city water, you wouldn't have a problem. I see a lot of residential properties that have 1/2" cpvc or copper plumbing for outside spigots. This greatly reduces the flow of water and you will often only see 3.5-4.5 gpm flow with an 8gpm well pump. If you do go with an 8gpm machine, I'd recommend carrying an extra supply hose so you can connect to 2 wate. spigots when needed.
 I just learned something I did not think about. I keep 200 ft of garden hose on the truck and I nerver thought about hooking up to both spigots. But the only problem I see with that is the potential of burning up the well pump or running the well dry. I never kept track of how much water i use during roof cleaning or house washing. Thanks for the idea Chris, and just in time because I was going to start my tanks install today and will need to change my connections that i had planned. I really want the 8gpm machine but it may not work with my set up. Thanks again Chris.. now I just need to figure out how to steal yiur rig and keep it with out getting caught.
-- Edited by Brian C Jackson on Tuesday 31st of December 2013 09:44:58 AM
Lol. You're welcome Brian.
I've never had a problem with burning up a well pump or running a well dry. We run 2 5.5gpm pumps on both trucks and always have 2 supply hoses hooked up. I would be more concerned with the pump continuing to cycle on/ off, just like a delevan burning up pressure switches. This is the case when installing a home irrigation system. You want to size your nozzles and amount of heads to have your well pump continue to run and not cycle on/off.
-- Edited by Chesapeake on Tuesday 31st of December 2013 10:14:10 AM
I'm running a 6.3 GPM works fine
I been 11.8 gpm. Best to have 2 supply to the house, or keep a guy in the front yard watching the tank!
 Hi Mike
 Hi Mike
 How bad did you get the snow up there?? News said it was pretty bad.
gutterdog wrote:
 Hi Mike
24" with some huge drifts Been out plowing since fri night at 12 Got a few hours sleep
