Liberty SoftWash (formerly Roof Cleaning by A&E) offers professional roof and exterior cleaning in Pennsylvania and Maryland. Liberty SoftWash specializes in a safe and gentle soft wash cleaning technique that is ideal for cleaning all of your home's exterior surfaces. Softwashing is a low pressure cleaning technique that will not only clean a surface but will also kill any algae or bacteria that may be present. We have found that surfaces stay clean longer than traditional pressure washing with water alone.
Our soft wash roof cleaning will return your home's roof to a like new condition by killing and eliminating the algae, lichen and moss that may be growing. A dirty roof is not just an eyesore. A roof with black streaks actually causes your attic space to heat or cool unevenly because of the hot spots caused by the algae growth on a roof. Much like a dark shirt on a hot summer day, the black streaks collect more heat which also causes premature aging of shingles as well.
SoftWash roof cleaning is the only way a roof should be cleaned. A professionally trained roof cleaning professional will only use pumps and other equipment that are designed to operate at low pressure and will never use a pressure washer to clean a roof. A pressure washer, even at the lowest pressure setting runs at a pressure that will cause damage to a roof's surface. You should never pressure wash your roof. SoftWash cleaning is the only recommended technique to clean roofs. All of the products used in our roof cleaning process are 100% biodegradable.
In addition to cleaning roofs, the SoftWash cleaning technique is an excellent option for cleaning the exterior of your home or business. This low pressure cleaning method is ideal for vinyl siding, dryvit, stucco, aluminum siding, brick, stone and more.
Liberty SoftWash also offers pressure washing services for your interior or exterior surfaces. Our pressure washing equipment operates with both hot and cold water to clean even the dirtiest surfaces. With our water reclaim system, we are able to offer tile and grout cleaning, or interior cleaning sanitation services for commercial kitchens and bathrooms.
Liberty SoftWash is an excellent choice for all of your residential or commercial cleaning needs in Central PA and Northern MD. Call us today to schedule your home exterior cleaning makeover. (717) 324-4208
