Post Info TOPIC: One Restore
One Restore
Today I used One Restore to clean Rust on siding and a Roof. The stuff worked Good and I got it Local $36 bucks a gallon. Check it out. Send them a email and see if you can get it near you. They have some new products coming out also.
http://www.eacochem.com/ProductDetails/productDetails_OneRestore.htm
AcryliStrip is a solvent-based sealer, stain, and paint stripper that has a wide range of applications.
n
  • Product Specification:
    PDF
  • MSDS:
    PDF
A.R.T. is a solvent-based resin system designed for treating the surface of anodized aluminum to renew satin luster that has been damaged by environmental or chemical pollutants.
ar
    PDF
  • MSDS:
    PDF
Boss is an alkaline-solvent base oil spot remover that whitens concrete while removing oil stains. Boss is also used to remove food oil from exhaust hoods.
n
    PDF
  • MSDS:
    PDF
Brite 10 BC is a hydrofluoric acid based aluminum brightener that leaves a soft shine.
br10
    PDF
  • MSDS:
    PDF
Burn Restore is an acid burn repair system for glazed brick.
n
    PDF
  • MSDS:
    PDF
Calcite Presoak is a pre-soak softener to facilitate quick removal of calcite on brick, block or concrete; water stains on limestone, block, precast, and unpolished marble.
cp
    PDF
  • MSDS:
    PDF
Calcite Presoak Gel is designed as a pre-soak softener to facilitate quick removal of heavy calcite deposits on block, brick or concrete. The gel has powerful penetration and softening action.
cpg
    PDF
  • MSDS:
    PDF
Cleansol BC is an all-purpose alkaline cleaner for use on painted metal, EIFS, vinyl, roofs, porous concrete, siding, wood, etc., while acting as a neutralizer for acids used in high rise restoration.
clbc
    PDF
  • MSDS:
    PDF
ConSALT is a corrosive salt remover and protectant for salt deposits from trucks, concrete, metals, and sensitive surfaces.
cslt
    PDF
  • MSDS:
    PDF
CP & B (Clean Polish & Brighten) is an aluminum and chrome brightener.
n
    PDF
  • MSDS:
    PDF
C-Tar Melt is a water soluble, rinseable tar remover that is safe for wood, metal, and masonry surfaces and will not raise the grain or cause discoloration of the surface.
ctar
    PDF
  • MSDS:
    PDF
CT Presoak Gel is a first step concrete remover designed for heavy excess concrete on mixers, trucks and construction equipment.
n
    PDF
  • MSDS:
    PDF
CT Wash is a concrete remover designed for use on light to medium build-up of excess concrete from mixers, trucks and construction equipment.
n
    PDF
  • MSDS:
    PDF
Dazzle BC is a one-step polished aluminum truck wash that can be brushless in some applications.
daz
    PDF
  • MSDS:
    PDF
Ef-fortless is a soap solution that counteracts efflorescence and helps to prevent its return.
eff
    PDF
  • MSDS:
    PDF
Glory BC is a brushless truck wash which utilizes the “Million Mile Shine” system.
glor
    PDF
  • MSDS:
    PDF
Graf-Ex is a liquid stripper that removes ink, marker and graffiti from interiors, painted surfaces and fiberglass. Graf-Ex will also remove decal adhesive, silicone caulk and sealer from sensitive surfaces.
graf
    PDF
  • MSDS:
    PDF
GS Restoration (GSR) is a non-hydrofluoric restoration detergent designed for glazed brick, concrete and terra cotta cleaning.
gsr
    PDF
  • MSDS:
    PDF
HD Britenol is an all purpose mild acid cleaner designed for use on homes and in light duty commercial applications which can be used on a variety of surfaces.
hdb
    PDF
  • MSDS:
    PDF
HD Degreaser is an extended dwell carbon and grease remover.
hdd
    PDF
  • MSDS:
    PDF
HD Sabre is a non-hydrofluoric acid, biodegradable general purpose cleaner used to clean aluminum, stainless steel truck bodies (non-coated), and the floors of food trailers.
hds
    PDF
  • MSDS:
    PDF
InStrip is a paste-type multi-layer, interior and exterior paint stripper that can lift primers, solvent and water-based paints.
ins
    PDF
  • MSDS:
    PDF
LCS is a water based stripper for removing sealers, stains, and paint. LCS is also an effective graffiti remover from masonry surfaces.
lcs
    PDF
  • MSDS:
    PDF
Mop & Grip is a floor wash which removes foot traffic film, leaving behind an attractive shine.
mop
    PDF
  • MSDS:
    PDF
NMD 80 is a buffered detergent-based solution designed for removing mortar smears and efflorescence from new masonry structures. NMD 80 can be used on virtually any type of brick, block, stone, cast stone, pre-cast and glass.
nmd
    PDF
  • MSDS:
    PDF
OneRestore® is a commercial grade restoration detergent and stain remover, with a wide range of applications and substrates.
one
    PDF
  • MSDS:
    PDF
OneRestore GEL, extended dwell OneRestore, removes stains from heavily stained or crusted surfaces.
oneg
    PDF
  • MSDS:
    PDF
PLUS is a high pressure degreaser for use with a pressure washer which removes thick grease from heavy equipment and rolling stock.
plus
    PDF
  • MSDS:
    PDF
Polished Stone Cleaner (PSC) is a neutral cleaner for polished stone, including marble.
psc
    PDF
  • MSDS:
    PDF
Purple Plus BC is a water-based degreaser for removing heavy grease, oil buildup, and stains from heavy equipment, rolling stock and concrete.
pur+
    PDF
  • MSDS:
    PDF
RS10 BC is a reclaim soap for truck washing and degreasing.
rs10
    PDF
  • MSDS:
    PDF
Rust Clear is a non-corrosive cleaner that removes rust stains and stops surface rusting on painted surfaces.
rust
    PDF
  • MSDS:
    PDF
Showboat is a biodegradable polished aluminum truck wash with versatility in the ways it can be applied.
n
    PDF
  • MSDS:
    PDF
Silicate Sealer Remover is a blush remover and recoat prep.
n
    PDF
  • MSDS:
    PDF
SIZZLE is a highly dilutable brushless pressure wash soap.
n
    PDF
  • MSDS:
    PDF
Smoke Melt is a highly alkaline cleaning product that will remove heavy soil deposits from metal, wood or masonry at high dilutions, strip latex and enamel paint, and softens heavy black smoke.
n
    PDF
  • MSDS:
    PDF
SOS-50 is a buffered organic salt and detergent-based solution designed for removing mortar smears and efflorescence from new masonry structures. SOS-50 can be used on most masonry substrates.
sos
    PDF
  • MSDS:
    PDF
Stripper Cream is a thickened multilayer paint remover. Stripper Cream will also remove thick black crust from Limestone.
str
    PDF
  • MSDS:
    PDF
Stripsol LO is a solvent-based sealer, stain, and paint stripper that has a wide range of applications. This product’s low odor ability allows it to be used both indoors and outdoors.
n
    PDF
  • MSDS:
    PDF
Truck Wash Supreme SC is a fast one step brushless truck wash that is safe on painted surfaces and polished aluminum.
tws
    PDF
  • MSDS:
    PDF
White Scum Presoak is as a pre-soak softener to facilitate quick removal of white scum on block, brick or concrete.
wsp
    PDF
  • MSDS:
    PDF
W.O.W.W. is a mild acidic wash and wax type product that is safe for all surfaces.
woww
    PDF
  • MSDS:
I sent them a emal and they called me back in minutes with a local supply house. Very nice guy. One thing he said is to keep it off soft medals on the roof. It can run onto the shingle. He said if that happen, just spray One Restore on it and rinse it off.
Looks good!
I love OneRestore. I use it frequently !
I just sent them an email to see if they have a local up here. I like having options.
a lot of brick/masonry supply companies will carry it.
Just about everyone has One Restore, the miracle chemical. If something doesn't work most people say, try One Restore.
It does a great job cleaning windows and sky lights after roof cleaning as well as dried SH from windows that didn't get rinsed well after a house wash. We use a Lafferty Model 50 Compact Sprayer  to apply. The first thing you will need to do is remove the 4050 tip and replace it with a 0030 or 0040. It has 20 color-coded precision metering tips to set dilution ratios. It doesn't take much.
Half to full strength will remove medium to light rust from asphalt shingles.
