Post Info TOPIC: Fat Boy 100 psi any good
Now In: Delavan Ag Pumps, Inc. → Delavan FB 2 Diaphragm Pump 12V, 100PSI, 7.0GPM, DEM
Click here to view larger image
mailicon.gif E-mail this product to a friend
SKU:  7870-101Y
Brand:  Delavan Ag Pumps, Inc.
Delavan NEW FB 2 Series 7 GPM Diaphragm Pump. Demand Switch – Operates only when liquid flow is required
Features:
• Delavan proudly announces the FB 2 our new 7 GPM pump
• The FB 2 is the most powerful 12 volt pump Delavan has ever made
• The FB 2 has been developed by the world’s most experienced engineers in diaphragm pump technology to achieve 10% increase in flow through-out the pump pressure range
• The FB 2 out performs other 7 GPM rated 12 volt pumps
• It features a more powerful, longer life motor
• It sustains it performance in continuous use, while other pumps experience a significant drop off in performance after a few hours of running
• The FB 2 is the most cost effective pump for the flow in the field today
• This US made product is 100% assembled and tested in our factory in Minneapolis, MN
Specifications:
• Demand Switch – Operates only when liquid flow is required
• Volts: 12 VDC
• Motor: 12 VDC permanent magnet, totally enclosed, non-ventilated
• Leads: 14 AWG, 12” long
• Pump Type: 5 Chamber positive displacement diaphragm
• Pump is capable of being run dry
• Excellent self-priming capability
• Max. Flow: 7.0 GPM
• Pressure Shut-Off: 100 PSI
• Amps: 11 – 25
• Liquid Temp.: 140° Max.
• Priming Capabilities: 14’
• Inlet/Outlet Ports: 1/2” FNPT
• Pump Housing: Nylon
• Valves: Viton
• Diaphragm: Santoprene
• Fasteners: Stainless steel
• Weight: 8.0 lbs
That's a good price for that pump. I do think Bob from pressure tek was selling them but went back to the original fatboy because of some problems. I think the motors were burning up but that was last year.
Mike is correct...I'd stay with the original...don't need no problems.
i have 2 of them and I have one of the original.. I dont notice a difference in distance nor reliability..
Lee Kendall
443.880.7011
That's good to hear Lee, maybe they fixed the problem.
