Post Info TOPIC: Non SH based house wash?
Anyone have thoughts or suggestions on a good, contractor grade product for house washes that does not depend on SH?  I'd like to add something like that to the arsenal for those individual case basis that arise from time to time.
Ted Saunders
Founder, American-ProTech
Roof Stain Removal Services
House Washing Services
We just use GreenWash without the bleach and a soft brush if necessary or extremely weak SH. Why are you asking, have you run into someone with chemical sensitivity?
Tim Teed
302-559-7533
Vesta Wash Roof Cleaning
Northern De/Southeast PA
http://www.VestaWash.com
jomax works, but I think it has SH in it.
I think Everspec sells some different stuff
Thanks Art. A little spendy, but it's an option I guess. Here's a list of their products and MSDS www.envirospec.com/MSDS.htm
Tim - no chemical sensitivity issues per se' other than the occasional blue ribbon koi pond with $3000 imported fish. (Serious!) We're about to go after the house washing market here hard, and I simply want a genuinely bio-friendly option for those that request or require it.
Ted Saunders
I have used both of these with good results...
www.newagain.net/House-Wash.html
absolutechemical.com/house-gutter-products.html (the citrus gutter and house cleaner)
Soap WareHouse has some exterior soaps also www.soapwarehouse.biz/exterior6.html
I do a lot of expensive homes around Philly and those concerns really never came up from the homeowner. We have worked around Koi ponds but never that close, and usually it might only be one side. If that was the case we would just spray and scrub with GreenWash without SH. We would carry some of the ? chemical that removes chlorine from fish tanks just in case some SH gets in water. I do like that citrus cleaner from Absolute and it works great on gutters. It does make sense to offer a SH free option though, and I will give it some thought.
Tim Teed
302-559-7533
The chemical that I think you're referring to is sodium thiosulphate.  Or you can pay 100x more for DeChlor at the local pet shop      We always pre-treat the koi and goldfish ponds as a precaution.  (I have a pond as well, so we discuss it and get the client's permission first)  The fish ponds are easy enough to overcome, but the whole bio-friendly option could be just that, an option.  Let me know what you come up with and I'll do the same.
Ted Saunders
I agree that you have to be careful around ponds. We cover them if they are in misting area and we have treated them as well, with no issues. When you bring up a more bio-friendly option.....I actually think SH is one of the most friendly options. It pretty much degrades into the soil as salt. I think the types of detergents/surfactant really has the most to do with bio-friendliness. One of the main things is that they are phosphate free. Phosphates can take years to degrade and can also effect the drinking water of a well.
anytime a customer has concerns about chlorine I just point out it is the most eviormently friendly option when used correctly.
It is used in schools, hospitals, workplaces, in your water and in the salt that your body needs.
What matters is who is applying it and their level of knowledge and experience.
We use a citrus based cleaner for fascia & soffit but it is toxic to aquatic life so be careful if you are thinking of using something similar.
What do you pretreat ponds with Ted and how do you do it.
This is the best answer! The whole green is still a big question. The pressure washer vs soft wash is proven. Without question, soft wash with sodium hypochlorite works when in the right hands. The solution for house was is so mild there is nothing that works better than a simple SH/soap solution.
Adam - overcoming the SH concern during the sales cycle is not the issue, as we do that all of the time (we specialize in roof cleaning and go through a BUNCH of SH).  This is more about streamlining the marketing and appealing to an additional subset of the client base;   The front end if you will.
John - your  point about phosphates is spot on.  I'll research alternatives accordingly.  Thanks!
Michael - we pre-treat with any of the consumer grade de-chlor products from the Pet Stores.  Our clients are familiar with those products whereas raw sodium thiosulphate would likely raise some concerns.  (I know it would with we me and my pond.)  Dose heavily, simply as a precaution.  It's well worth the $10 or so per pond that it costs us.  Pre-treat the pond during the initial set up so that the de-chlor has time to circulate evenly.   Cover/tarp as you would ordinarily.  An ounce of prevention as they say....
Ted Saunders
Thanks Ted for the info.
Have i got this wrong. the sh is not the problem as its a gas and once exposed to the air it breaks down fast but the bio degradable surfactants on the other hand are very poisonous to aquatic life and last for at least 28 days.
This is my understanding
Thanks
Andrew
 Andrew Hall
 http://www.andrewswindowcleaningservices.co.uk/
 west wales/ uk
Sodium Hypochlorite is essentially chlorine and table salt. It is the salt that runs off that does the most damage to plant and animals. Chlorine gas evaporates fast but the salt runs off into ponds or the ground and if plants are thirsty they will absorb the saline killing them so a good soaking prior will keep them from uptaking the saline water
Andrew,
yes the soaps if high in phosphates are very dangerous to the aquatic life, but so is the chlorine. It will raise the PH level of the water well above what fish can live in.
The plants do not like the salts in SH. The main ingredient in Round Up is sodium based salts, which will poison vegetation.
As for JO MAX it requires bleach added but as others pointed out phosphates and other salts will be harmful, maybe implementing a reclaim or other barrier system may work
