Water Dragon Low Pressure/High Volume Applicator #5407
Water Dragon Low Pressure/High Volume Applicator System:
This unit is designed to give you 10.5gpm at 300psi with the ability to adjust the flow and pressure using the built-in regulator. It is also ready to run dual guns with the two ball valves at the pump if desired. Just add a second line and you have 2 guns at 5.75gpm.
- Heavy Duty Aluminum Skid with Vibration Isolating Rubber Feet
- Honda GX160 engine with electric start
- Udor Zeta 40P/GR Pump with Pressure and Flow Regulator (this poly pump will help stand up to the harmful effects of bleach)
- Udor 1 1/4" Inline Filter
- 300' 1/2" Orange AG Hose
- Plastic body chemical applicator gun with Viton seals
- 4 nozzle holder with #60 0, 15, 25, 40 degree nozzles
- 20" stainless steel lance with quick connects
*FREIGHT NOT INCLUDED
