Post Info TOPIC: Blue Kuri Tec
Blue Kuri Tec
I was thinking about purchasing the 1/2 Kuri Tec blue  hose (maybe 200 ft) I know the yellow can handle more pressure but it is more expensive. Do you think I would regret buying the blue Kuri tec?
Did some searching but really couldnt find out the diffrences besides psi.     Thank You!
We have run blue hose for 6 yrs now and love it. We use 5/8 at 300 ft.
It depends on what you are using the hose for?
I would be using it to apply a strong mix of sh. For surface cleaning. I would just down stream but some times I need a stronger mix. Thanks guys!
kuri tec is not for down streaming w a pressure washer
Call or Text 281.883.8470
I want to buy the kuri tec hose for a soft wash setup. Im not planning on using it for down stream. I was just wondering If the blue hose was alright to use. Thanks!
Looking to lay down some SH on concrete with it.
Eric says it's good. Like Doug says it's not for a pressure washer. When I was considering it I couldn't find a difference except color.
Good to know thanks a bunch!
The Kuri-Tec K1154 or K1156 are both the same thing,..one is red and one is blue. I use the red,..and it is one of the better hoses used for low PSI application,..and yes,..it will handle high percentage of SH. MANY people have used this hose,..the yellow is likely the 600 PSI stuff and won't be as manageable anyhow.
-- Edited by Jeff Wible on Monday 22nd of February 2016 06:11:56 AM
 LOL!
Thanks Jeff
I read your post wrong....yes blue and red kuri tech is what we use as well for our dedicated pumps.
