Post Info TOPIC: Which water vacuume?
I clean interior breeze ways of large Condiminiums.. We are currently using squeegees to push the water.
 I need to vacuum the water and remove it. Not reclaim it.
 Need suggestions. Sirocco surface cleaner and vacuume or just a big vacuume?
It depends on a few things. What are you willing to spend and do you want a Cadillac when an Impala will do the job?
I want to vacuum water and reroute it as cheap and efficient as possible
Get a shop vac for wet pick up. A big one. Hook a drain hose to the drain, with a valve and run the hose outside. When the tank starts to fill up, open the valve to drain off the water. Once you get it set right, you can leave the valve open while you are sucking up water. As long as the level of water in the vac. is above the drain hole.
Kleen Roof & Exterior
616-914-9064
Pressure Washing Michigan
Michigan Cedar Roof Pro
Dave Dykstra
I use a ridgid 14 gal. 6hp.
616-914-9064
Dave Dykstra
