Post Info TOPIC: Downstreaming remote
RE: Downstreaming remote
A_J Pressure Washing wrote:
I read everything I can find about it and watched all the YouTube videos on it.
Unless you know where I can find more info on it
There is no way you read everything! Believe me... there seems to be a lot to it until you get everything right for your machine(s). Each machine needs a different injector (unless the gpm's are close to the same) and the mix will be different depending on the gpm's. I'm sure you can tell you have found the right place for the correct answers. Jeff is a walking encyclopedia and one of the seasoned veterans... you are fortunate to have his help.
There is so much information and equipment when it comes to soft wash and pressure washing. In the beginning it can be a bit daunting. My plan of attic was to build my own system as so many here have done. Every supplier has their own from a hand truck portable to a dual axle trailer with all the bells and whistles.
These videos will help.
https://www.youtube.com/watch?v=y8EWa0-9_g0
https://www.youtube.com/watch?v=CAbGHKnshbg
Jeff Wible wrote:
Oh,..and your zip code?
 Zip is 28421
All Kleen Softwash Systems
910-372-3702
Anita & Joe Ingram
AllKleenSoftwash@gmail.com
Find us on Facebook
Formerly A & J Pressure Washing
Yea Art I was thinking the same thing.
That's why I decided to step away from research today lol let my brain rest lol
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Anita, just so you understand a Down Stream injector goes on a power washer and you can't wash a roof with it. The S/H isn't strong enough. Most of us started out with a DC 5850 Delavan pump. You can buy the setup at Pressure Tek or make one yourself like most of us did. Keep things simple starting out and go from there. You are just confusing yourself with all these different set ups.
 +1
 I have watched those videos.  They are very informative.  I'll be ordering that bypass hose and ball valve this week for sure
910-372-3702
Anita & Joe Ingram
Find us on Facebook
We don't DS much as we direct apply our solution from our Udor and rinse with pressure washer.
Eric,.with basic siding washing,..why the use of two hoses compared to one? Just wondering where the advantage is for you. I could understand better if you were doing alot of stucco or something that requires a higher SH ratio than DS'ing can provide,..But DS'ing is so simple,.especially with a remote unit.
We have 2 guys on the truck and he would stand there with nothing to do.
Oh,.I knew you'd have a good reason,.Ha,Ha,..
LOL! See I do know something.
 Thanks Brett,..I take that a compliment coming from a strong source!
Hey jeff, should I bring a 1 inch pvc out of my chemical tank, then reduce it down to the chemical injector tube?
Or just the small injector tubing all the way to the injector?
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Anita,..you will not be using anything like a 1" PVC pipe. A soap injector uses 1/4" clear hose,.usually dropped into a 5 gallon bucket as your "chemical tank"
You're getting confused I think with soft washing pumps and setups,..the Pressure Washer and soap injector is a whole different application process.
I'm getting ready to head out now,..so I'll have to pick it up later. Keep reading.
Jeff....whats the parts needed?? Can you PM me, I'd like to try to build one...
Me too! Please.
Got my parts from Jeff paid for. And I can't wait to get my hands on them. Going to make life much easier woohoo
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Just to be clear,..you aren't only getting the "parts",..you are getting a working,.. self powered unit. All you need to do is set your unit so the "bucket hose" goes into the bucket and the "injector hose" goes onto the little barb on the soap injector,..and it will be ready to work.  And remember the blue wire inside the ammo box is the antenna,..stick it out the hole I made so the plastic box isn't insulating the signal.
I sent it with hoses,.but you may have to add longer hoses,..depending on where you locate it.
Please read and really understand the basics of downstreaming to utilize the remote. The remote's main job is to shut the soap off without having to go back to the machine to turn the soap on/off,...and this is so we can rinse with low pressure soap nozzles. Which is really important,..and the remote makes a World of difference.
-- Edited by Jeff Wible on Saturday 4th of June 2016 05:50:13 AM
Wow, I thought I was getting the parts to build one, this just keeps getting better lol
Ty Jeff for your help. Can't wait to get it.
910-372-3702
Anita & Joe Ingram
Find us on Facebook
And by the way,.you may have the only self powered remote downstreaming unit in the whole wide World Ha,Ha,...
Lolol now I'm going to find me some LED lights so I can tell it's working, or I could just wait for the foam to come out when I get my foaming stuff
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Considering these remotes work very well,..the lights really aren't needed,..just make sure you press the button totally.
The biggest benefit to the lights is actually for when you accidentally bump the "on" button and you maybe you'll see the light telling you this.
Go to Walmart and get a "Flashing Beacon" they are now carrying for $20.00,..Open up the light housing and remove the cigarette cord and solder on the wires and connectors needed to hook it into those auxiliary connectors.
Will do
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Another thing,..the remote transmitter I sent with unit is in a little plastic cell phone type pouch,..I added silica packets to help keep moisture level down inside. But seeing this was my spare,..I never taped it up to seal it better,..you may want to do that,..and also add a binder clip so it will easily attach to your waist line.
Just zip tie the binder clip to the plastic pouch using the existing hole that is in the top of the pouch. This is the best way to carry the transmitter and also have it very accessible.
*Taping" the pouch up also gives the cheap "welded" seems much better strength.
-- Edited by Jeff Wible on Sunday 5th of June 2016 06:55:14 AM
Sounds great man. Thanks
910-372-3702
Anita & Joe Ingram
Find us on Facebook
Jeff I hooked up that remote injector and omg that thing is nice ty agian
910-372-3702
Anita & Joe Ingram
Find us on Facebook
You're welcome! Anyone who uses downstreaming as an application method should have one of these as standard equipment. Such a huge benefit with so little cost and effort.
You'l see,..when you build your spare one,.you'll want to build another,.Ha,Ha,.. Because,.you will NEVER want to be out a remote once you get used to having it.
Solder connections and use dielectric grease. Good solid connections saves ALOT of headache down the road.
Just to keep those interested up to date,..I am liking this solenoid. I take it apart about once a week for the last month and it doesn't even look used at all.
http://www.ebay.com/itm/290909115114?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Keep testing Jeff, You will get it dialed in sooner or later
Oh it's dialed in Art,..the solenoids are just sacrificial parts,..but yes,..I do like testing different components. To get a month out of a $12.00 solenoid is VERY well worth the minimal cost. If any DS'ers aren't using a remote ,..they are REALLY missing out.
Bump
Only 10 left!
They're shipping out of Centereach L.I.
Maybe Art can go pick me up for us interested
http://m.ebay.com/itm/290909115114?rmvSB=true&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Ftype%3D3%26campId%3D5336838522%26toolId%3D10001%26customId%3Diu71kj21wj000dx600004%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252F290909115114%253F_trksid%253Dp2060353.m2749.l2649%2526ssPageName%253DSTRK%25253AMEBIDX%25253AIT%26srcrot%3D711-53200-19255-0%26rvr_id%3D1108442994391&_trksid=p2060353.m2749.l2649&_mwBanner=1&ul_noapp=true
-- Edited by Maverick Contracting on Wednesday 12th of October 2016 11:00:43 AM
«First  <  1 2 3  >  Last»  | Page of 3  sorted by
