TOPIC: Gray 3/4" check valve
These are the valves I use.  You can use schedule 80 fittings also
https://www.usplastic.com/catalog/item.aspx?itemid=42418&clickid=search
-- Edited by Art O on Sunday 24th of March 2019 04:19:51 PM
I'm running this valve for my soap this year. I'm seeing some Proportioners with them, but I'm not sure how good they work
https://sunplay.com/products/pentair-control-valve-r172086?variant=6882184036387&gclid=CjwKCAjw1dzkBRBWEiwAROVDLCEX4xUx4pwsUIgvoo_QFrLgT_cyKwDxMCyIROMLXpscVJ71QwC5nxoCcVcQAvD_BwE
Gray 3/4
Still using these check valves. Been about 6 years. The trick to them is you have to epoxy them together. High flow, no restriction like the black valves. I'm going to switch the bleach side out this winter. Been a while
RE: Gray 3/4" check valve
 These valves crack easy, Seen a guy putting a hose clamp around them. I'm going to give it a shot again
Pentair Control Valve R172086
Item #: R172086
$43.95
Maverick Contracting wrote:
I think we're about to see a new vendor enter the market.
The SoftARTSystem
 Works just fine with a little glue
Hooked up the check valves today and I'm about done. Just need the Booster
 This was a fun build
«First  <  1 2 3 | Page of 3  sorted by
