TOPIC: Full bore hose barb fittings.
Ran across these 1/2" fittings where the guy had them special made so that the barb opening is a good bit less restricted than most barbs.  Not sure if it's something people are interested in, but if you want max flow I thought it was a good deal.  He has pictures if you scroll down, where you can see the difference.
https://www.brewershardware.com/1-2-Threaded-Hose-Barb-TFM12B58.html
Another cool thing is that they have a 3/4" FNPT x 1/2" full bore barb.  This could come in handy for anyone that uses banjo or gator camlocks.
Most people might know this already, but the barbs on camlocks are very restrictive.  I measured a 3/4" gatorlock barb and it was a full size smaller on the barb opening, measuring the same as a normal 5/8" barb.  I would imagine the same is true for a 1/2"... so if you are using 1/2" camlocks, they are really 3/8".  This way you can screw in 3/4" camlocks on a 1/2" line easily, and eliminate the restriction.
https://www.brewershardware.com/3-4-Threaded-Hose-Barb-1-2-High-Flow-Female.html
-- Edited by Jason Watkins on Wednesday 25th of April 2018 08:58:28 PM
Z8MfHE4.png?1
http://www.ClearWaterSoftWash.com
Great find Jason.
You gotta appreciate brewers!
Those fittings will help with flow and can help volume and distance .
Good find Jason. I found these 1/2"npt at Home Depot near the Pex stuff. They are schedule 80 and have a larger bore than the banjo. They are like $.39 each.
Western Mass ProWash LLC
Steve Croteau
WESTERNMASSPROWASH.com
(413) 366-1003
Wilbraham, MA
wmprowash@gmail.com
Good find Jason. I have shifted away from plastic barbed fitting this year and trying stainless steel to help reduce downtime.
I bought 2, see how they work out. Nice find Jason
These Hose barbs aren't cheap, but they hold up way better then brass
They last a little longer, but still need to be changed out. Bleach side tank
  Didn't you just get those??? And they rusted that fast?
I use plastic fittings wherever I can. Sourced from lowes for sprinklers
  Not sure how old they are, maybe 3 or 4 months. Nothing holds up for long
 Why not schedule 80 PVC barb?
Yea,..I was wondering why not use something in the plastic line,..like Brett said,..schedule 80. Sometimes there needs to be places where strength is more important. But that usually pertains to something in the pressure washer side of things. Like hose reel fittings,...but I don't think that is the case here.
I still use a FatBoy and I don't like restricting the flow. Everything from the pick up tube to the pump has a clear path. Schedule 80 barbs have a smaller hole, these barbs don't. I'm still using the 3/4" gray check valves also with good results. They just need to be epoxied together. I don't like the black check valves everybody uses because they restrict. We all have different opinions on this stuff and this is my way. Learned way back at the RCIA that less restriction is better
   This post says I bought them in April
ART I have schedule 80 fittings that are next size up to not restrict flow. I have to see what size they actually are but you can definitely get it done w plastic and non restrictive.
Pretty sure I just has to heat up and stretch the 1/2 hose over the fitting.
I'll look later when I pick up truck but think they are 1/2"mpt X 5/8barb
I get it now Art but Erik brought up something I still do, but not as often. Heat and stretch! I think you can get a 1/2 x 5/8 barbed schedule 80 fitting. I'm in Richmond today so I can't check our stock.
  I've use the schedule 80 in the past also. I used to grind the outside down to make it fit in the hose better.
I often heat hose so it goes over a hose barb easier,..I don't have a heat gun,...(Need to get one though),...I simply use very hot water,...depending on the hose material determines how hot the water should be or how long it needs to stay in,...works very well though. I typically microwave a cup of water for 2-3 minutes. The small diameter (1/4"-5/16") PVC clear hose heats very quickly,..with even just hot water from the tap.
Great idea Jeff! Getting them off could be tough w/o a heat gun. Here a cheap one from Harbor Freight. I found having a better one is good to have around when a tanks needs to be repaired.
I usually cut it off. It wastes about 1&1/2 inches of tubing but much easier then getting it off any other way
I just picked up a heat gun at HF, I have been using it alot. Its a handy tool to have
